2/6/2022 11:02 AM | |
Joined: 11/14/2021 Last visit: 2/8/2022 Posts: 5 Rating:
Hello expert, In CNC I can not able to boot due to attach file alarm at drive.and screen at HMI not boot. |
2/6/2022 11:24 AM | |
Hello Ashu4141, Since your 802D system is not booted/started, 831 alarm is displayed i.e. significance of 831- Profibus is not in data transfer condition. So please check why 802D is not booting & what is status of 7 segment display (it is on rear side of PCU). Better way is attach the snap shot of OP screen. If 24 Volt supply is present at PCU connector & no screen is visible, then probably PCU might be faulty. |
2/7/2022 12:27 PM | |
Hello,good day to you, Thank you mr.piscean for your response.i here by attached pic of op screen. I attached here 6phpto with 7segment display including, in display start time showing 1then showing 4 and after that no no. Showing only blind. AttachmentIMG-20220207-WA0007-converted.pdf (239 Downloads) |
2/8/2022 6:02 AM | |
Thanks you for help. |
