2/14/2023 10:19 AM | |
Joined: 6/19/2017 Last visit: 8/5/2024 Posts: 8175 Rating:
Hello locost33, Best regards, |
2/14/2023 2:36 PM | |
Joined: 1/14/2023 Last visit: 8/4/2023 Posts: 9 Rating:
Recording attached in zip file
Attachment20230213_153424.zip (303 Downloads) |
2/18/2023 3:07 PM | |
Hi all, still stuck with a mill that I cannot run. Any suggestions to get it running again please. |
2/19/2023 1:23 PM | |
Thank you for the response. Looks like things have changed since my original post. The machine has been switched off since my original post. At the time of the original post the switched on with the switches s3 and s4 at 0 made the same sequence, 5-2-1, flash. Having switched the machine power supply back to ON this time (s3 = 0 and s4 = 0). I now see the same response I had when i first powered in on after xmas. Vid attached. The screen now shows the message "waiting for NCK connection" Can you advise next steps please? Do I try the reset procedure in "810D NC PLC clear & reload proceduer.pdf" (I will attach in next post). and then load the backup files through dnc? AttachmentRestart_19Feb2023.zip (302 Downloads) |
2/19/2023 1:24 PM | |
Procedure I had tried to follow
Attachment810D NC PLC clear & reload proceduer.pdf (372 Downloads) |
2/21/2023 7:32 PM | |
Any updates please |
2/22/2023 9:35 AM | |
Thank you. I will get onto that then |
