8/10/2016 11:50 AM | |
Joined: 5/18/2015 Last visit: 5/8/2024 Posts: 98 Rating: (1) |
I have a sinumerik 828D Basic & I want configuration for Orlikon 4 axis Machine. Spindle motor is Ac 3Ph 22Kw siemens & Micromaster 440 Axis drive is Double motor module. I want configuration & set PLC programing. I have sinumerikcommissiong software but unfortunately I can't install correct. Before Sinumerik 828D I configuration another Orlikon machine by Sinumerik 808D advanced . Please help me for configuration & PLC programing this machine. Thanks a lot. ------------------------------------------------------------------------------------------ AttachmentCertificate for Sinumerik 828D.zip (291 Downloads) |
Last edited by: Min_Moderator at: 8/10/2016 1:24:42 PMNew subject after splitting SKAZEMCNC |
8/11/2016 3:55 PM | |
hello again i buy SINUMERIK Softwere by sinumerik 828D & i install this softwere select all SIEMENS Soft but unfortunately SinumerikCommissioning not install correct! i send error about SinumerikCommissioning & DVD. thanks Attachmenterror.zip (179 Downloads) |
SKAZEMCNC |
8/12/2016 5:58 AM | |
Joined: 4/23/2010 Last visit: 12/31/2023 Posts: 8092 Rating: (876) |
Hello, Are you able to read toolbox DVD on your PC/PG? Have you got CF card with system software? Have you tried to install it by powering up system? Please follow this link & connect all the hardware items & complete installation as per recommendations. How you are connecting your PG/PC with system? Its not clear whether you are not able to install CD on your PG or you are not able to load software on system? |
8/19/2016 6:08 AM | |
Yes it is possible. Please refer the attached sheets (extracts from commissioning manual) which explains about setting different machine data for interfacing analog spindle. Are you intend to run this spindle as only rotary axis or you intend for positioning axis also? Depending on this, PLC logic needs to be develop. HTH. Attachment828D - analog spindle .pdf (269 Downloads) |
