12/13/2007 10:02 PM | |
Posts: 328 Rating: (29)
Dear Sir Are you using a Simatic USB stick? Although i have made other devices bootable, it works best with a simatic stick. 6ES7648-0DC30-0AA0 Regards SteveJ |
5/23/2009 4:29 PM | |
Joined: 5/22/2009 Last visit: 5/3/2022 Posts: 40 Rating: (0) |
I have got the same problem but after three usb stick the last one work.it’s a “1gb my flasf Adata” from www.adata.com may be not easy to found again !If you know more compatible key post it The more strange is that the previous one boot on my laptop but not on the PCU50.3.May be because the bios is different ?Ultimately I make a usb bootable key myself I use the Hewlett packard free software “HP USB disk storage Format Tool V2.0.6 “Select FAT for file system , don’t put a name for Volume label And select Create a dos startup disk (you need a image of old dos system) And start After put some software for net and Ethernet card driver , and ghost |
