6/8/2022 9:32 AM | |
Joined: 1/4/2007 Last visit: 6/13/2024 Posts: 1131 Rating:
Hello Edek, Attached you can find the released Siwarex-software in different PCS7 versions. Which order number has your Siwarex U module (7MH4601-xxx or 7MH4950-xxx)? If the order number is 7MH4601: Offically, you can’t use this old Siwarex U module in PCS7 V91SP1. You can try to use your old FB650, but without guarantee. If the order number is 7MH4950: Offically, you have to use the new FB653 in PCS7 V91SP1. You can try to use your old FB650, but without guarantee. Maybe the faceplates aren’t working correctly. Best regards Siwarexi
Attachmentmatrix_2022_02.pdf (408 Downloads) |
