6/20/2011 10:35 PM | |
Posts: 14 Rating:
Sirs why i cannot find the driver modules for this card, while working in CFC. the SM 326 DO 8 x DC 24v/2a PM (6ES7-2BF40-0AB0) please helppppppppppppppppppppppp |
6/21/2011 2:44 AM | |
Joined: 9/27/2006 Last visit: 7/14/2024 Posts: 12268 Rating:
Hello amro; Do you have the PCS 7F-package? SIMATIC Process Control System PCS7 Compendium Part B - Process Safety http://support.automation.siemens.com/WW/view/en/35016980 |
6/21/2011 12:20 PM | |
Posts: 14 Rating:
sir thank you for your help, i checjked the manual , i cannot find the module driver for this card , i only find it for the DO 10 |
6/21/2011 1:01 PM | |
Posts: 14 Rating:
dear sir i am using the following S7 F Configuration Pack V5.5 SP5, but i still couldn't find the module driver can i contect you by phone??? |
6/21/2011 3:23 PM | |
Hello amro; According to this FAQ, http://support.automation.siemens.com/WW/view/en/15208817 your module should be configurable from version 5.3, SP3 of the S7 Configuration tool. Version 5.5, SP6.1 of the configuration tool allows the configuration of the replacement module 6ES7 326-2BF41-0AB0. So your configuration tool should allow you to use and parametrize your F-DO module. I suggest you contact Siemens support directly (see the Support Request link at the right of this page) for more detailed help. Hope this helps, Daniel Chartier On a personnal note: please stop abusing the emoticons in your posts,doing sodoes not bring any better help from the members. D.C. |
6/21/2011 3:35 PM | |
Joined: 10/7/2005 Last visit: 7/14/2024 Posts: 3009 Rating:
Hello amro allow me to ask you which version of PCS7 you are using. The 6ES7326-2BF40-0AB0 was relased in late 2004 (see HERE) and only appeas in the list of PCS7 supported modules as ofV6.1 (see HERE). If you have V6.0 or ealier I wouldn't be at all that much suprised if you can't find a channel driver for it (theF configuration packsonly make F I/O modulesavailable in HWconfig but do NOT contain PCS7 relatedchannel drivers as far as I'm aware). I hope this helps and please let us know what you find P.S: I agree with dchartier, less can be more and one crying face would have done the job. |
Cheers |
6/22/2011 7:01 AM | |
Joined: 3/21/2006 Last visit: 4/25/2024 Posts: 10228 Rating:
Please, attach the error. |
6/22/2011 10:09 AM | |
Posts: 14 Rating:
pleae find attached the error
AttachmentDesktop.zip (116 Downloads) |
