8/10/2011 7:32 PM | |
Joined: 12/13/2010 Last visit: 7/29/2022 Posts: 33 Rating:
Hi Marian,
Hardware Compatibility Check pages 6 and 7.
Marcelo T. Suzuki |
Last edited by: SUZUKI_BR at: 8/10/2011 7:42 PMLast edited by: SUZUKI_BR at: 8/10/2011 7:39 PMLast edited by: SUZUKI_BR at: 8/10/2011 7:38 PMLast edited by: SUZUKI_BR at: 8/10/2011 7:36 PMIf you have any further questions please don't hesitate to contact us. |
8/10/2011 10:05 PM | |
Ok, Try Pull the bus connector off the card. The bottom right LED should go solid green. Regards, Marcelo T. Suzuki |
8/11/2011 1:19 PM | |
Posts: 48 Rating:
Hi Mr. Marcelo, All my status LED are off Module Status = OFF ( no power) Network Status = OFF (no power , not online ) Only operational LED is blinking green.( apparently at 2 Hz, but not continuously, se my previuous post) In anybus manual is saying that at 2Hz module is not initialized http://www.hms.se/upload/Anybus-S-2401-ABS_M_Parallel_DG_2_08_SCM-1200-015.pdf I have pulled the network connector and no change, status LEDs off, op LED blinking same. I am attaching a picture with the module installed Regards Marian |
8/12/2011 1:26 PM | |
Very good that we solved this problem. Best regards Siemens Industry Sector |
