5/28/2012 3:52 PM | |
Joined: 7/8/2009 Last visit: 8/5/2024 Posts: 1976 Rating: (477)
Have you got firmware mismatch errorat startofdownloading? I checked and found some of them are communication related parameters. They may not be much importance as per your application but you can make list and compare offline and online values after downloading completed which version of drive monitor you are using? and what is drive firmware version? Download latest version of Drive Monitor from here Regards Devesh Vithani |
I dont Like people driving Fast, thats the reason I overtake them ;) |
6/1/2012 6:09 AM | |
Posts: 9 Rating: (0) |
Thanks for your support, I change the parameter P060 and that problem still occurs. May be that is not the solution, Regards
6/1/2012 9:00 AM | |
I checked my Masterdrive and its version is OK. May be it is only the notice, not a fault. Thank you for your help. |
11/19/2012 7:32 PM | |
Posts: 2 Rating: (0) |
is MLFB correctly set |
11/19/2012 7:33 PM | |
if so i got some trick for you. got same problem last month please kep me inform |
