6/13/2018 4:50 PM | |
Joined: 4/28/2015 Last visit: 6/3/2024 Posts: 3345 Rating:
Hi community, attached you cand find an application example how to install and create a SQL database (MariaDB) on the IOT2000 and how to connect to this database via node-red and C/C++. Note: You should have SQL knowledge if you want to use an own SQL database instead of the one in the example. How to manage SQL databases is not part of this document! Best regards! Attachmentsql_client_server.pdf (3519 Downloads) |
Not working for IOT2050 support anymore from March 1st, 2024. |
7 thankful Users |
11/6/2018 1:27 PM | |
Posts: 10 Rating:
Hi, i can't download your pdf file, because it protected with username & password, can u open your protect?, so i can access this file, big thanks... |
11/6/2018 1:40 PM | |
Posts: 10 Rating:
i try it after reply your post, and doens't work, still username and password required, i dont know what to do... |
11/21/2018 5:04 AM | |
Posts: 32 Rating:
With the SQLite nodes no longer working is this thread no longer useful or can the database created here still somehow be used ? Thanks Kas |
11/22/2018 7:11 AM | |
Hi, there is a difference in the nodes mysql and sqlite. The two are not the same. Best regards! |
