4/27/2009 1:07 PM | |
Posts: 103 Rating: (11) |
how are you all AttachmentNew Bitmap Image.zip (227 Downloads) |
4/27/2009 2:34 PM | |
yes sir , the lay out of SW source is in the picture in the attachment , my fiend in the compamy succeed to install the same source on his laptop hint , 1) my fried has the same windows 2) I made uninstall to SQL 2005 of WINCCFLEXIBLE before install the new SQL Attachmentsql.zip (204 Downloads) |
4/27/2009 3:34 PM | |
Joined: 3/21/2006 Last visit: 4/25/2024 Posts: 10228 Rating: (1181) |
Hello, Did you look Why can't you install the SQL server from WinCC V6.2 or WinCC V6.2 SP2 after installing WinCC flexible 2008? Best regards Hristo Mihalev |
4/27/2009 4:43 PM | |
yes sir , I took alook at this FAQ , I executed all instructions in it . |
4/28/2009 3:15 PM | |
many many many thanks CBO , I will try to do your suggestion , I will tell you the results thank you |
