1/8/2009 5:05 AM | |
Joined: 9/27/2006 Last visit: 7/14/2024 Posts: 12268 Rating:
Hello Aguste; The Simotion ST Programming manual shows how to use implicitdata type conversion: http://support.automation.siemens.com/WW/view/en/27002409 For example: Table 3-46 Example of data types in expressions and value assignments VAR usint_var : USINT; real_var : REAL; byte_var : BYTE; string_var : STRING[80]; END_VAR
real_var := 234 / 10; // Implicit conversion possible Result = 23 usint_var := 234 / SINT#10; // Data type of expression: INT// Implicit conversion and // value assignment not possible real_var := 234 / 10.0; // Data type of expression: REAL Result = 23.4 usint_var := 234 / 10.0; // Implicit conversion and value assignment not possible byte_var := string_var[5]; // Implicit conversion possible; value assignment not possible string_var[10] := byte_var; // Implicit conversion and value assignment not possible Hope this helps, Daniel Chartier |
