7/2/2009 10:46 AM | |
Joined: 3/18/2009 Last visit: 5/6/2024 Posts: 306 Rating:
This is from anold postregarding the error ID494D. I don't think anything has changed since then. Now there aren't many reasons that I know of that can cause just the standby CPU to stop. But if you can do this test (it requires downtime)
Another thing is if you can check the diagnostic buffer of both CPUs separately after your standby CPU is in stop. Post it here if you find any different errors. I assume you have already created a Service request, if not do so ...(and let us know when your problem is solved) |
