3/22/2020 6:37 AM | |
Joined: 11/15/2012 Last visit: 6/6/2024 Posts: 143 Rating:
Greetings,We are testing TIA V16, but for startdrive V16 update1, I cannot install it, even I installed TIA Portal V16 upd1. This is log: Is this normal? I installed it in a fresh Virtual Machine.... 2020.03.22 13:05:18 - Year.Month.Day - Log start AttachmentSIA_STARTDRIVEUPDATE_V16_Upd1@20-03-22_13-02-53_summary.txt (410 Downloads) |
Last edited by: C.Change at: 03/24/2020 14:23:11Last edited by: C.Change at: 03/24/2020 14:24:58 |
3/22/2020 10:59 AM | |
Joined: 8/11/2006 Last visit: 6/21/2024 Posts: 29 Rating:
Hi C.Change I had the same problem, too. Check other log files, I find this on "Patch.merger.log": --------------------------------------------- Logger Start --------------------------------------------- But I still don't understand which is the problem... I install all TIA V16 (Step7 professional, WinCC Advanced, Safety, etc... and startdrive V16, too) without any problem. Also the other UPD1 pachage I install without trouble. Any suggestion will be appreciated. GP AttachmentPatch.merger.txt (360 Downloads) |
3/24/2020 11:17 AM | |
Joined: 10/11/2006 Last visit: 7/10/2024 Posts: 5872 Rating:
Hello, please contact the Technical Support - they have some recommendations for you. https://support.industry.siemens.com/cs/my/src?lc=en-WW Thank you! |
With best regards, |
3/24/2020 5:16 PM | |
Thank you. I had made the Support Request, hoping it helps. I thought it may be solved and did not want disturb Siemens support team. If I get a solution, I will update here ASAP. Edit: I had made a SR, a good siemens guy made a call to ask me about details, he will ask for developing division and forward my logs (about 139mb in zip) for any help, for now, I could only wait. TIA Portal V16 will work without startdrive V16 update1, which is lucky, because it may be not working as not same TIA Portal update version... Best Regards. |
3/29/2020 7:24 AM | |
Unfortunately, there is no solution right now. If someone has some information, please share... |
