8/20/2013 9:25 AM | |
Joined: 4/22/2010 Last visit: 10/17/2024 Posts: 5697 Rating: (715) |
Hello, I think you should start with the manual: SIMATIC HMI Touch Panel TP170 A, TP170 B Operator Panel OP170 B There you will find how to setup your TP. Regards, Marcjan |
Problem solved? |
8/20/2013 4:13 PM | |
Joined: 1/21/2013 Last visit: 10/18/2024 Posts: 4620 Rating: (708) |
Hi a.z.r, You can send us a some pictures from when it begins the startup? |
8/20/2013 4:53 PM | |
Joined: 4/24/2006 Last visit: 10/18/2024 Posts: 8746 Rating: (1169)
Hello a.z.r, It looks there is a project on TP170B? Do you need this project or do you want to delete it and start from scratch? If so, you can perform an OS update, with option "Reset to factory settings" selected. (Project will be lost) how do you do an operating system update (OS update) on operator panels? Best regards, Wizard |
9/9/2013 10:33 AM | |
Posts: 3037 Rating: (192)
Hello, This screen is a screen for your ProTool project. You must logon with your user in your project. Tweety |
9/9/2013 11:25 AM | |
Joined: 6/8/2013 Last visit: 10/1/2024 Posts: 188 Rating: (1) |
hi Mr.Tweety can u explain about logon with user? i have not any project on this TP and that is bought recently . |
