4/18/2024 12:58 PM | |
Joined: 8/3/2009 Last visit: 8/7/2024 Posts: 13486 Rating:
Hello do you use In/out Parameter of an instance DB in this case? If yes then perhaps this could be the reason: https://support.industry.siemens.com/cs/de/en/view/109476062 https://support.industry.siemens.com/cs/de/en/view/109478253 Bye Murof |
