3/20/2015 2:11 PM | |
Joined: 9/27/2006 Last visit: 9/20/2024 Posts: 12282 Rating: (2684) |
Hello VIKEing; May I suggest you read some old threads that transited on the forum earlier, on this same subject: Difference between FB and FC's Differences between Function Block (FB) and Function (FC) You will have to take into consideration that you can have common DBs, structured by the user for his own programming needs, and Instance DBs (IDB) that are created (and structured) by an FB to store the static values required when you call this particular instance of the FB. Hope this clears up some issues. Daniel Chartier
