1/2/2008 2:46 PM | |
Joined: 9/28/2005 Last visit: 8/27/2024 Posts: 2957 Rating: (242) |
Hello, Recently I have downloaded SP6 and have problems with installation. When you try to install SP6 it says that you need to uninstall your previous version of Step 7-Micro/Win. If uninstallation wasn't succesfull you can look at this topic https://support.automation.siemens.com/WW/llisapi.dll?query=uninstall+microwin&func=cslib.cssearch&content=skm%2Fmain.asp&lang=en&siteid=cseus&objaction=cssearch&searchinprim=&nodeid99= In my case, I still had problems, becouse SP6 installer said that I must uninstal older version, but I have allready uninstalled it. So I tried to reinstall that older version (4.0.5.08) sever times and then uninstall it, but SP6 installer generated the same error and nothing helped. So I found the solution. You must search through registry for entry 4.0.5.08 (I tested it only on this version) and delete all entries that relates to Microwin. Be carefull when deleting entries, becouse I found entries with these number, but they wasn't related to Microwin or Siemens. It's best to do registry backup before deleting anything. Maybe there is no such problems with older versions tan 4.0.5.08. I asked Siemens Support for help, but we didn't find a solution. I think it's becouse of previous version of MicroWin. So if someone has similar problems it could be useful to look at this thread :) Regards, |
Best regards, |
1/2/2008 3:24 PM | |
Joined: 9/23/2005 Last visit: 9/11/2024 Posts: 4347 Rating: (1445) |
Hi, |
Denilson Pegaia |
