6/22/2016 2:10 PM | |
Joined: 4/24/2006 Last visit: 5/17/2024 Posts: 8649 Rating: (1151) |
Hello, What are the exact versions of software you have installed already? (incl. any updates) Best regards, Wizard |
6/22/2016 2:14 PM | |
Hello, Here you can find latest updates for Step 7 v13 sp1: Updates for STEP 7 V13 SP1 and WinCC V13 SP1 And you need the latest update for Step 7 safety v13 sp1: Updates for STEP 7 Safety V13 SP1 Please install latest updates for Step 7 v13 sp1, WinCC v13 sp1 and Step 7 safety v13 sp1. Best regards, Wizard |
6/22/2016 2:42 PM | |
Joined: 5/12/2006 Last visit: 5/14/2024 Posts: 22251 Rating: (2985)
Hello, you can install the Safety SP1 without any problem, but after that you must install UPD5 so that tia is start correctly. The UPD5 can be downloaded here: https://support.industry.siemens.com/cs/ww/en/view/109477092 Regards Christoph |
6/23/2016 6:10 AM | |
Posts: 2 Rating: (0) |
I installed the Step 7 Safety and after that update 5, everything is working. Thank you. |
2/28/2017 3:00 PM | |
Joined: 3/2/2007 Last visit: 5/8/2024 Posts: 929 Rating: (5) |
it is difficult to have all versions the same, each time a new sp is released... |
... thank you ... |
11/14/2017 1:07 PM | |
Joined: 6/19/2017 Last visit: 5/17/2024 Posts: 8034 Rating: (164) |
New question published by BHXControls is split to a separate thread with the subject Can install the Step 7 Safety V13 SP1 straight into TIA Portal or do need to install Step 7 Safety V13 first?. Best regards |
