4/12/2011 8:26 PM | |
Joined: 1/28/2009 Last visit: 7/15/2024 Posts: 6844 Rating:
How do you update invalid block calls (time stamp conflicts) in calling blocks?
4/13/2011 10:02 AM | |
Posts: 316 Rating:
Hi Iwein, after updating the UDT did you close your editor? If you want to use the new structure of the UDT you have to open the editor, where you will engineer your programm again. The structure of the udt will be "loaded" with the open process of the editor (in SCL after compilation). |
4/13/2011 10:32 AM | |
Check the attachment,doing the job without closing any window. regards AttachmentHD_UDT.zip (199 Downloads) |
