10/9/2019 2:48 PM | |
Joined: 2/1/2010 Last visit: 7/25/2024 Posts: 149 Rating: (71) |
I think there is no problem to use your PCS7 install to do a Step7/CFC project. Probably every (non-TIA) S7 project I've edited for the last 10 years has been on a PC with PCS7 installed. Just be careful of the version of SIMATIC Manager and CFC versions included in your PCS7 install are the versions you intend for the final Step7 project. Also remember there are extra libraries as a part of the PCS7 install, so I advise to not use them since you won't have access to them on a standard install S7 station. |
If my post helped you, please rate. Thanks. |
10/10/2019 12:10 PM | |
Joined: 10/21/2016 Last visit: 10/31/2023 Posts: 49 Rating: (0) |
Okay, thanks! |
