4/15/2008 10:49 AM | |
Joined: 9/27/2006 Last visit: 7/3/2024 Posts: 12266 Rating:
Hello suren; The only software problem you will have if you install Step 7 5.3 in any version of Vista is that it will not work. Have a look at the followingcompatibilty matrix for Windows and Step 7: https://support.automation.siemens.com/WW/llisapi.dll I can also suggest you use the Search box at the top right of this page to look at other threads from users using various versions of Step 7 on Vista; use the search term "Vista". Hope this helps, Daniel Chartier |
4/15/2008 11:05 AM | |
Posts: 121 Rating:
Hello suren. SiemensSTEP 7 V5.3 is not with Vista kompartibel. Under Vista functions only the version 5.4! Then, however, for it "Microsoft Vista Business" is required also. You can read up more infos under the following link: (Keywords: Compatibility list, Compatibility, Compatibility matrix) http://support.automation.siemens.com/WW/view/en/8250891 Many greetings Patrick Hehl |
4/15/2008 11:43 AM | |
Posts: 158 Rating:
Hey patrick, thanks for the reply, its was straight to the point, atleast now i have the whole compatibility table. thanks alt. |
