10/11/2023 1:02 PM | |
Joined: 10/10/2005 Last visit: 4/18/2024 Posts: 1917 Rating:
Hello AutoGen_906708, I recommend to install again the S7DOS64 driver with the install program PC-identifier. You should use the latest version of PC-identifier and should do a repair installation. You should additionally check if online connecting is possible. If the problem persists, I recommend to send the latest SDT-files and the development to the Technical Support. https://support.industry.siemens.com/cs/ww/en/view/65976201 With best regardsCicero |
