9/21/2014 9:10 PM | |
Joined: 9/21/2014 Last visit: 7/5/2023 Posts: 11 Rating: (0) |
Dear all, I have a problem from conversion PLC program from STL to LAD. (1) When i convert from STL to LAD in OB1 block, all netwoks in block converted to LAD, but NETWORK 1 not converted ,still remain in STL. (2) Second same problem is in same program in another function block FC01, in FC01 some networks are converted successfully from STL to LAD, but some remain still in STL. Kindly help me. I want to view all networks in LAD. plz see attachements of OB1 and FC01. AttachmentFC1.pdf (153 Downloads) |
9/21/2014 9:11 PM | |
Here is attachement of OB1.
AttachmentOB1.pdf (135 Downloads) |
9/21/2014 9:33 PM | |
William B. thanks very much, But problem is that i not understand STL format, i know LAD, FBD very well. |
9/21/2014 9:37 PM | |
Joined: 1/21/2013 Last visit: 9/4/2024 Posts: 4620 Rating: (707) |
Studies |
9/21/2014 9:43 PM | |
Posts: 5225 Rating: (1192) |
..small steps my friend.. small steps. If you have the enough confidence to ask questions here, you can learn what you need for understanding STL. For now I have given what you need (I hope). Knowing LAD and FBD is not good enough for your own good. This is an uploaded program (guess) - so you need to better your skills. Get yourself some books on the subject of STL and SCL. Some things code better in STL and SCL... or even GRAPH. I think you can teach yourself these things.. please go out there and do some effort and prove me right! w |
9/21/2014 9:46 PM | |
Thank you my dear friend.. always good to hear from you! I have a bit of an issue with the link you gave... it does not help a ground level beginner of STL. Do you have some other ideas you could share - - - please!? w |
9/21/2014 9:55 PM | |
Thanks dear William B. for your kind and useful replies, I will try, hopefully the this matter resolved. Thanks V.M |
9/21/2014 10:19 PM | |
Hi William, Manuals and programming examples are installed on your computer together with STEP 7. Search ---> First steps with STEP 7 and Working with STEP 7. In Simatic Manager go to Documentation directory with the Start button They will show you how to use FB DB and FC. And |
Last edited by: Ste39 at: 9/21/2014 10:27 PMAdd link Last edited by: Ste39 at: 9/21/2014 10:25 PMLast edited by: Ste39 at: 9/21/2014 10:20 PM |
