9/2/2010 3:31 PM | |
Joined: 8/31/2005 Last visit: 6/14/2024 Posts: 2198 Rating: (328)
That's normal, see here.
Last edited by: miami at: 9/2/2010 3:46 PMLast edited by: miami at: 9/2/2010 3:36 PM |
9/3/2010 7:26 AM | |
Posts: 72 Rating: (0) |
I always followed the above points mentioned by u, its in my general practice.
Now again question goes to you why my cpu will not communicate with pc when inserting mmc i.e., Stop led blinking. |
9/3/2010 8:12 AM | |
Hello, I am not putting new MMC card. I am using MMC which is placed in another CPU.
9/3/2010 8:45 AM | |
Hi, When same MMC is inserting in another cpu, then its working properly. When another MMC is inserting in the cpu(315-2DP)then also its not working. |
9/6/2010 2:07 PM | |
try this: - follow this steps: https://www.automation.siemens.com/mdm/default.aspx?DocVersionId=22452494475&Language=en-US&TopicId=21300382859 - Do not enter a MMC (at the moment). - Set the CP setting to automatic (or MPI with 187,5 kbit/s) --> Now you should be able to contact the CPU (e.g.read diagnostic buffer) |
