9/28/2015 10:46 AM | |
Joined: 3/14/2008 Last visit: 5/24/2024 Posts: 2069 Rating: (928) |
Hello, The alarm warnings like QH_ALM, QH_WRN will still be enabled, only you lock out the messages/alarms. What you need to do is configure the horn in WinCC, by setting alarmclasses. So the horn will sound when alarms are showing up. If you lock out alarms, they won't show. Below is a link to PCS7 8.0/8.1 on how to configure the horn, but you need it for PCS7 7.0. couldn't find it so quickly. |
