4/29/2016 6:26 PM | |
Joined: 12/4/2009 Last visit: 9/30/2024 Posts: 453 Rating: (136) |
Pratts23, NTP is the best option for you. Assuming that your operating system is Windows 7, this document will explain everything: How do you configure time synchronization using the NTP procedure It is a PCS7 document, but nevertheless it explains step by step how to configure NTP server or client. Hope this helps. |
If this post actually helped, you may consider using the Rate button above. |
4/30/2016 3:23 AM |
Joined: 7/19/2011 Last visit: 10/10/2024 Posts: 262 Rating: (5) |
Thanks for the information. |
JAVED AKHTAR |
5/2/2016 7:15 AM | |
Joined: 11/21/2007 Last visit: 9/25/2024 Posts: 2325 Rating: (308) |
This a good ( and Zero cost ) option for time synchronisation in a small plant. However it has one deficiency that you need to manually keep updating the time in the NTP Server as any clock will need adjustment from time to time.
There is no such thing as the last bug in a program |
