10/16/2010 11:10 AM | |
Joined: 4/23/2010 Last visit: 12/31/2023 Posts: 8092 Rating: (876) |
Have you checked the ohmic value of thermal sensor when you are getting high temp alarm signal. Please check it & if it is changing then it is recommended to get the motor serviced from Siemens. I am attaching the sheet for your information.
AttachmentPFK7.pdf (355 Downloads) |
10/16/2010 11:32 AM | |
Posts: 31 Rating: (2) |
i already replaced a new motor and power and data cable but the problem still exist. |
10/19/2010 5:49 AM | |
Do you have spare control card? Pls check by replacing it. Regards, DEEP. |
