3/20/2024 10:48 AM | |
Joined: 2/12/2024 Last visit: 4/17/2024 Posts: 3 Rating:
Hi rdoliveira, Im currently converting TP177A Hmi to winCC scada v8.0 and found out an issue regarding alam. IN the HMI they had configured the alarm and given an tag in the alarm description based on that the alarm will get change but as if now we cannot do that tag in alarm description for winCC explorer .Is their any other way. ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 03/20/2024 12:46:05New subject after splitting |
3/26/2024 10:33 AM | |
Joined: 8/3/2009 Last visit: 7/10/2024 Posts: 13244 Rating:
Hello AutoGen_8967270 OK then i have understood correctly. Check the manual: https://support.industry.siemens.com/cs/ww/en/view/109792585/127124154635 Bye Murof |
3/27/2024 6:34 AM | |
in this manual its showing how to do in simatic hmi we are trying to confingure in wincc explorer
