10/22/2012 11:22 AM | |
Posts: 3037 Rating:
Hello Sachin Patke, You find more information about tag multiplexen in the following link. How does tag multiplexing work? Tweety |
10/23/2012 7:18 AM | |
Joined: 10/7/2005 Last visit: 7/25/2024 Posts: 3011 Rating:
Hello Sachin Patke have a look atHow does address multiplexing work? which will help you to save tags (and which you would have also found at the top of the page onHow does tag multiplexing work?thatTweety provided you with I hope this helps |
Cheers |
10/26/2012 10:54 AM | |
Posts: 3037 Rating:
Hello Sachim Patke, You can only use structure tags in faceplates in WinCC flexible. Structure tags cannot be used in a script. You can look this information in the following link ---> piont 15. Tips and tricks for creating scripts You must change your PLC project. Tweety |
