7/1/2019 2:17 PM | |
Joined: 3/31/2017 Last visit: 6/18/2024 Posts: 43 Rating:
To manage a device I've declared an input and an output UDT so that I can use them into a custom Tag Table. Unfortunately I've encountered the issue visible in first image: as you can see, output "User_Data_Length" should start from byte 6, but TIA Portal is forcing it to byte 7. AttachmentUDT.zip (63 Downloads) |
Last edited by: Dav3i at: 07/01/2019 14:18:03Last edited by: Dav3i at: 07/01/2019 14:47:11Last edited by: Dav3i at: 07/01/2019 14:58:37Last edited by: Dav3i at: 07/01/2019 15:33:30Last edited by: Jen_Moderator at: 07/02/2019 09:41:34Removed link and inserted numbers of image in the text. |
7/1/2019 3:07 PM | |
Joined: 7/7/2010 Last visit: 6/28/2024 Posts: 14865 Rating:
If you configure the DB as non-optimized, you can do odd things like you describe. Personally, I would insert a byte of "reserved" space to put the data on an even numbered offset.
science guy |
7/1/2019 3:44 PM | |
Any reason you did not use the approach provided by Cognex here? https://support.cognex.com/en/downloads/detail/in-sight/3687/1033
science guy |
