11/28/2023 11:32 AM | |
Joined: 7/19/2022 Last visit: 7/24/2024 Posts: 378 Rating:
Hello Azad Sukemi, The label multiplexing available in WinCC Advanced and in panels is not available in WinCC Professional. You can do something similar to this by using tag prefixes to select the correct tag. See the manual section below: Addressing tags indirectly (RT Professional) |
