3/1/2019 9:15 AM | |
Posts: 1 Rating:
Hello, _Pavel_, I have a current issue with a similar setup as you stated, therefore, I was wondering if you had implemented this setup in your project? If so did you experience any issues? Our current is that we have good communications via ProfiNet but the TCP/IP seems to be intermittent? Our setup uses VLAN's based in a Siemens Scalalnce XM-400. Thanks your time ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 3/1/2019 12:39:38 PMNew subject after splitting |
