9/29/2024 6:18 PM | |
Joined: 9/29/2024 Last visit: 10/18/2024 Posts: 3 Rating: (0) |
i have the same prblm yet my pg/pc is set to S7online but still having the same prblm knowing i am working with simatic step7 using cpu 315-2 pn/dp trying to set a new connection TCP/IP in my tag management when i active the project it gives me this question mark of unknown connection can you please help me with it ? ------------------------------------------------------------------------------------------ |
Last edited by: Moderator_Lan at: 09/30/2024 11:11:31New subject after splitting |
10/2/2024 2:13 PM | |
Joined: 7/19/2022 Last visit: 10/30/2024 Posts: 413 Rating: (70) |
Hello AutoGen_9296809, From the previous post, the most common topics have already been tested: SIMATIC NET, PG/PC interface.....I would consider updating WinCC 7.4 to the latest available updates: |
10/17/2024 12:20 PM | |
i already have the WinCC 8.0 but yet still having the same prblm ! best regards |
