5/31/2016 9:58 AM | |
Posts: 9 Rating: (0) |
Hello, I'm looking for technical data (in .pdf) about SINAMICS V90, PROFINET,1/3 AC 200V 0.4kW and SINAMICS V90,PROFINET,1/3 AC 200V 0.75kW . Thanks you in advance. |
5/31/2016 11:20 AM | |
Posts: 1529 Rating: (202) |
There is a PROFINET V90? Since when? Screw technical info, I want release info. |
5/31/2016 11:24 AM | |
Joined: 5/12/2006 Last visit: 9/3/2024 Posts: 22352 Rating: (3008)
yes V90PN partially is available https://support.industry.siemens.com/cs/ww/en/view/109737089 Technical Data are in this document: https://support.industry.siemens.com/cs/ww/en/view/109737880 Regards Christoph |
5/31/2016 11:27 AM | |
Joined: 4/23/2010 Last visit: 12/31/2023 Posts: 8092 Rating: (877) |
Please visit below link & see attached sheet. Sales release for SINAMCIS V90 with PROFINET interface |
5/31/2016 2:48 PM | |
hi, list of supported telegrams attached. Yes simotion support the V90PN.At the moment you must use the GSDML File https://support.industry.siemens.com/cs/ww/en/view/109737269 With TIA V14 a HSP is available to integrate the V90PN in the TIA Portal.
Christoph |
7/28/2016 6:39 PM | |
Posts: 1 Rating: (0) |
Hello Christoph;
which telegram did you use?
7/29/2016 2:07 AM | |
105 would be the standard one to use for positioning. |
7/29/2016 7:38 AM | |
Hi, yes I work with Telegram 105 and V90PN, no problem with it. Regards Christoph |
