9/18/2016 8:49 AM | |
Posts: 664 Rating:
Dear All, I am working with Simotion 435D controller. Please anyone tell me how to identify the telegram data of CU and Infeed. After automatic configuration CU defined with telegram 393 PZD 4/21 and address of 512-553 [I] and 512-519 [Q] . and for infeed it is Telegram 370 PZD 1/1 and address of 288-289[I] and 288-289[Q] I it is possible to change the address.? Please where i will get description of these bytes? Thanks&Regards,
9/18/2016 10:42 AM | |
Posts: 1529 Rating:
Yes, you can change the addresses, but I'm not sure why you find it necessary to do so. I've always found it to be simpler to leave them as the defaults since the physical address has no meaning to me. You can find a list of all of the telegrams and descriptions in the S120 List Manual. |
9/18/2016 11:14 AM | |
Joined: 1/4/2013 Last visit: 4/12/2025 Posts: 1170 Rating:
Totally agreed... System is enough complicated ( In Rockwell these telegram stuffs with related addresses are hidden and not configurable), why you need to change them and eventually create a conflict that needs to be solved ? Tip-> Leave them as they are... |
Searching for Siemens used/new equipments ? |
9/18/2016 7:26 PM | |
Posts: 664 Rating:
Dear Jeff and Davinator, Thanks for the valuable reply.. Please tell me where should i get the detailed description of Telegram byte description [which bit and byte description] of particular telegram? Thanks&Regards, |
9/19/2016 7:16 AM | |
Joined: 5/12/2006 Last visit: 4/10/2025 Posts: 22611 Rating:
Hello, Capter 2.7 in the S120 List manual https://support.industry.siemens.com/cs/ww/en/view/33974002 Regards |
9/19/2016 7:19 AM | |
Posts: 1529 Rating:
For the telegram descriptions, look in the S120 List Manual - Function Diagrams - PROFIDRIVE. ChistophD beat me to it. |
