8/24/2020 7:12 AM | |
Joined: 2/5/2013 Last visit: 7/25/2024 Posts: 320 Rating:
Hi nguyenphuochuy, We need more information regarding your question. If STOP/RUN – Solid yellow indicates then CPU is in STOP mode, If STOP/RUN –Solid green indicates then CPU is in RUN mode, Flashing (alternating green and yellow) indicates that the CPU is in STARTUP mode. What is your actual requirement . 1.Whether you want to change the operating mode of CPU from Digital Input? 2.Whether you want to check why CPU is in STOP mode? Br, AmolG |
Please rate it. |
8/24/2020 8:40 AM | |
Joined: 9/3/2019 Last visit: 1/25/2024 Posts: 26 Rating:
Solid yellow indicates then CPU is in STOP mode, Can you help me! |
8/24/2020 9:02 AM | |
Can you share documents about Use a Siemens HMI that allows mode switching of the PLC ? thanks ! |
8/25/2020 12:27 PM | |
Joined: 6/19/2019 Last visit: 7/10/2024 Posts: 697 Rating:
Hello, I found in Siemens support about changing S7-1200 from STOP/RUN from HMI and there are sample how to do that. HERE IS LINK |
