5/10/2016 10:11 AM | |
Joined: 3/5/2014 Last visit: 8/5/2022 Posts: 5521 Rating: (1052) |
hi Karthikeyan, what Terminal module do you use? TM-E15C24-AT (6ES7193-4CL30-0AA0) TM-E15S24-AT (6ES7193-4CL20-0AA0) this are the two suitable TM´s. Is there any diagnostic shown? SF-LED? Maybe a look in the manual can give you a hint what is going wrong with your module: 2AI TC HF analog electronic module (6ES7134-4NB01-0AB0) This is a High-Feature product. It has a internal reference junction, so you normally don´t need an other. And when there is a problem with it, you would have wrong values, not an overflow. hope this helps, regards, |
FCK WAR! |
5/10/2016 2:06 PM | |
Posts: 1 Rating: (0) |
Dear Sir, Thanks for your reply, I used 6ES7 193-4CA50-0AA0 as a terminal connector |
