5/4/2012 6:56 PM | |
Posts: 6 Rating:
I have here at my plant 6 Ti505 CPU's (545-1104, 1106, 1101) I would like to put them onto our engineering network using a serial server such as the LANTRONIX XPress-DR IAP. We are in the (slow) process of changing the system over to S7400 CPU and we also have various other S7300 PLC on the system. To save a lot of footwork placing the Ti505's onto the network and using 505 Workshop to help in addressing programming changes and integration. Does anyone have any experience with this? What worked for you? Has anyone had success with conectiong through the LANTRONIX device and if so what were your terminations and settings? Any and all help with this is greatly appreciated Thank you AttachmentLANTRONIX_XPress-DR_PB.pdf (717 Downloads) |
