12/6/2022 10:42 PM | |
Joined: 1/21/2013 Last visit: 6/14/2024 Posts: 2886 Rating: (462) |
Hi RaniereLucas, there is no software "Totally Integrated Automation Portal Version V16", so you would not be able to buy it. The TIA Portal is the framework for other software like STEP 7 Professional V16 or STEP 7 Safety Advanced V16. For version V16 - it does not matter which update is used - you already have licenses for STEP 7 Professional and STEP 7 Safety Advanced. You will need SINAMICS Startdrive Advanced. You can use 6SL3072-4GA02-0XG5 or the current successor 6SL3072-4JA02-0XG5 since you are able to use the V18 licenses for V16 also. You also have older licenses for WinCC Advanced. Since the software is not listed, you should clarify if also needed. Otherwise you will only be able to use Basic panels inside the project. Kind regards |
