10/22/2021 2:29 PM | |
Joined: 4/9/2021 Last visit: 3/8/2024 Posts: 34 Rating: (0) |
Hi, Thank you for your response. TIA PORTAL V11 Release Delivery According to the Release Delivery link of TIA PORTAL V11 it is possible to install TIA PORTAL V11 Service Pack 2 on a 64 bit Windows 7. Can I get it working by installing it on Windows 7 64 bit on a Virtual Machine or should I just install Windows 7 32 bit version just to be sure it works? And is TIA PORTAL V11 Service Pack 2 only for 64 bit? By the way, just to add something, a copuple of weeks ago I managed to install TIA PORTAL V11 Service Pack 2 Update 5 on a Windows 10, 64 bit machine. Unfortunately I did not manage to install WinCC Professional(the setup installed only STEP 7 Professional) and I deleted STEP 7. Since then no success to install it again. Best Regards Konstantin Kolev
10/22/2021 6:26 PM | |
Joined: 3/2/2016 Last visit: 4/2/2024 Posts: 72 Rating: (14) |
Hello KonstantinKolev, You can check the compatibility of TIA Portal V11 with virtual machines/operating system using Compatibility Tool. |
10/24/2021 10:18 PM | |
Hi, I managed to install TIA PORTAL V11 Service Pack 2 successfully taking into account your suggestion. I created a Virtual Machine with a Windows 7 Professional Service Pack 1, which is one of compatible operating systems according the Compatibility Tester. The installation worked flawlessly without any errors. Thank you for you help and cooperation! [snip] ... Best Regards Konstantin Kolev
Last edited by: KonstantinKolev at: 10/24/2021 22:21:30Last edited by: CS Moderator at: 11/01/2021 10:51:41split new question |
