12/21/2016 11:09 AM | |
Posts: 8946 Rating:
Wrong direction, wrong datatype? |
12/21/2016 1:29 PM | |
Posts: 648 Rating:
Dear daisy, do you know the HMI-Toolbox https://support.industry.siemens.com/cs/en/en/view/106226404? Use the calculater to solve your problem :-). You have to use the same datatypes. With best regards rh1990 |
12/21/2016 1:49 PM | |
Joined: 8/3/2009 Last visit: 6/14/2024 Posts: 13030 Rating:
Hello daisy you should write: SmartTags("Real1") = SmartTags("Int1") + 5 Dont use a semicolon its not C Programming language. Also look at: https://support.industry.siemens.com/cs/ww/en/view/59885894 Bye Murof |
