8/3/2015 7:17 PM | |
Joined: 5/12/2006 Last visit: 7/31/2024 Posts: 22331 Rating:
Hello,
So please install TIA V13 only on the supported Operating Systems an you get no problem. And look in the compatibility Tool first before you install SW !
Christoph |
4 thankful Users |
8/4/2015 3:11 PM | |
Posts: 16 Rating:
You have to wait 2023! When there will be another operating system, of course, Tia portal will be compatible with it! Always a step backward!!! :D :D |
8/5/2015 2:52 PM | |
Joined: 2/6/2015 Last visit: 11/10/2023 Posts: 2 Rating:
Any updates? It would be nice to use Tia Portal directly on Windows 10. |
8/5/2015 3:21 PM | |
Hello,
then use it. Is your own risk! SIEMENS guarant no compatibility/functionality for TIA V13 with Windows 10.
https://support.industry.siemens.com/tf/ww/en/posts/129477/
Christoph |
8/7/2015 11:29 AM | |
Joined: 6/25/2013 Last visit: 9/7/2022 Posts: 25 Rating:
TIA Portal v14 is coming soon. I'm told support is likely to be added for Windows 10. |
10/1/2015 2:32 PM | |
Posts: 47 Rating:
Are anyone else running Windows 10 able to test this GSD file, to see if it is related to win 10 or something else? The file is Len_2133.gsd (gse) and is found on this website: http://www.lenze.com/en/application-knowledge-base/article/200412329/1/ Update: I tried installing a different GSD drive file from a different vendor, and the same thing happens. Not sure what to try next. Will probably try a reinstall of the Whole TIA Portal. |
