5/22/2020 1:42 PM | |
Posts: 15 Rating: (0) |
My machine is my pc the problem is that I only have access to the website in my pc. others machines not |
5/22/2020 1:46 PM | |
I used plcsim advanced |
5/22/2020 5:25 PM | |
Joined: 2/5/2013 Last visit: 9/12/2024 Posts: 321 Rating: (74) |
HiNajibsalah, Your question is not clear to me. I assume below things "That want to test PLC web server using PLC Sim Advanced. Program is downloaded in different PC where PLC Sim Advance is installed. You are able to access web server Web server of PLC for programming PC but not from other PC." Check whether you are able to ping IP address of PLC which is downloaded in PLC Sim Advanced. If not then there is network related issue.May be PC(Other PC)from which you want to check web server functionality is not in the same IP range of PLC(PLC Sim Advanced PC).Assign fix IP address to PC(Other PC)and check again. Br, AmolG. |
Please rate it. |
