2/9/2018 4:06 PM | |
Joined: 6/23/2013 Last visit: 6/27/2024 Posts: 58 Rating:
The TIA importer is to import PLC data types into WinCC OA. To link a data point element to a s7 tag, you have to add an address config and use there the symbolic selection button to select the s7 tag. Perhaps this topic is helpful. |
WinCC OA expert |
5/3/2019 11:51 AM | |
Joined: 7/19/2018 Last visit: 4/19/2024 Posts: 1 Rating:
Have you solved this problem? I have the same problem now, i tried to re install TIA exporter, but it doesn't work |
6/29/2020 3:36 AM | |
Posts: 1 Rating:
Hello. You can find out if you managed to solve your problem? Can you tell me how? |
