2/15/2013 3:04 PM | |
Joined: 1/28/2009 Last visit: 6/2/2023 Posts: 6803 Rating:
Hello , Test the followings with your hardware.Provide a s pulse in M200.0. OB1: [code] L W#16#ABCD T MW 4 // initialize identifier A M 200.0 // check trigger JCN ende CALL "SRT_DINT" // call SFC32 OB_NR :=20 DTIME :=T#10S SIGN :=MW4 RET_VAL:=MW8 CLR = M 200.0 // Make a short pulse on trigger ende: NOP 0 [/code] OB20 [code] L #OB20_SIGN T MW 10 L #OB20_DTIME T MW 12 /////////////////////////////// NOP 0 SET = Q 0.0[/code] Update you case.More information on STEP7 online manual or here: http://support.automation.siemens.com/WW/view/en/44240604 Best regards Hamid Hosseini |
