5/11/2014 10:58 AM | |
Posts: 1064 Rating: (72) |
are you using a int or word ? should be dint or dword to store this since 24*60*60 =86400 which is larger then a word or int can store |
5/11/2014 11:04 AM | |
Joined: 4/30/2010 Last visit: 8/6/2024 Posts: 137 Rating: (2) |
I am using INT that will explain it... thanks Ill convert it to DINT |
5/11/2014 11:25 AM | |
depending on what you are doing you could use a fifo buffer to track your changes |
