3/6/2024 12:16 PM | |
Joined: 7/19/2022 Last visit: 8/1/2024 Posts: 379 Rating:
Hello, Have you tried synchronizing the date/time via NTP between the CPU and the panel, as indicated in point 3 of the following FAQ? No connection to PLC after WinCC Panel Images V17 Update 6 Here you also have a guide document: Time synchronization between WinCC and a SIMATIC PLC |
Last edited by: JBS98 at: 03/06/2024 12:21:35If this Information really helps, you could use the Rate function |
3/6/2024 12:19 PM | |
Joined: 3/30/2020 Last visit: 7/31/2024 Posts: 4665 Rating:
@nunobnk.. We were having trouble getting a consistency with the method you describe. We decided not to proceed deeper into the reasons why there was a problem. Using FB110 (section 4.2) worked for what we were looking to do. The process could also be simulated without using hardware. |
Last edited by: qwazee at: 03/06/2024 12:20:32Activities of this user is voluntary. There is no obligation or liability placed on this user. Though optional, your 'please' and 'thank you' is highly valued. |
