1/11/2011 10:59 AM | |
Joined: 9/23/2005 Last visit: 3/24/2023 Posts: 4180 Rating:
Hi, Here there is some tips about the use of PWM in S7-1200. Sample program: The follow sample program is very simple. There is just the device configuration settings and a CTRL_PWM call. In the watch table, you can modify the digital output, and enable / disable the PWM to see how they works. AttachmentPWM.zip (5519 Downloads) |
Denilson Pegaia |
13 thankful Users |
6/21/2011 12:18 PM | |
Hi, When you change the duty cicle, you don't have more a PWM but a PTO. If your duty cicle is relactivly slow, I suggest you use the PWMof the link /tf/WW/en/Posts/42960#top and adapt it to your necessities. |
Denilson Pegaia |
11/19/2011 4:42 AM | |
Posts: 4 Rating:
why status output value is 16# 80A1 (PWM identifier does not address a valid PWM ).
AttachmentProject3.zip (1159 Downloads) |
