9/14/2024 10:51 AM | |
Joined: 9/7/2011 Last visit: 10/14/2024 Posts: 18 Rating: (0) |
hi dear friends i have a problem with TM Count 1x24V_2 and insert TM Count 1X24 in technology Objects ---> high speed counter in basic parameter module ---> please select the Hardware it doesn't recognize Counter Module. Can You help me. i want to order configuration to client. and need Profinet Redundancy R1. but with other Et200SP it does work. Does SIEMENS have solution for R1 ET200SP Example for Counting? ------------------------------------------------------------------------------------------ |
Last edited by: Moderator_Lan at: 09/16/2024 06:40:45New subject after splitting |
9/16/2024 6:42 AM | |
Joined: 7/30/2024 Last visit: 10/16/2024 Posts: 248 Rating: (5) |
Closed because posted multiple times. The active topic can be found here: TM Count 1x24V_2 not recognized Kind regards, Moderator_Lan |
