10/15/2024 11:05 AM | |
Joined: 10/11/2006 Last visit: 11/18/2024 Posts: 5941 Rating: (816)
Dear AutoGen_6695046, it is difficult to find out where is the issue of your described problem. Please check that your TO's and its periphery adresses are connected to your written function block. There must be two instances of the function block. Otherwise how to configure a technology object in a S7-1500 is described under the following link: Possibly you can find the issue by checking this application example. If not, you can try to implement our AxisCtrl function block into your program. Please find this example under the following link: |
With best regards, |
